198366809 发表于 2019-3-13 19:57:15
汽车电控系统很神秘?一文解开他的神秘面纱!
品牌、性能、省油等指标大家都耳熟能详,可是你们知道汽车的电气知识吗?https://5b0988e595225.cdn.sohucs.com/images/20190313/8bdc67ce628142319c0c3f29f3f8f087.jpeg一、汽车电气概述1.汽车导线标注及颜色代号http://5b0988e595225.cdn.sohucs.com/images/20190313/d62e7bad5cce40fc9508f250ddd34338.jpeghttp://5b0988e595225.cdn.sohucs.com/images/20190313/d5f7e860467f40f4a54a53850ba6afa9.jpeg2.电气设备符号http://5b0988e595225.cdn.sohucs.com/images/20190313/4b2fa9c412d24c8ba10bb7b0a9d059ad.jpeg3.电气元件符号http://5b0988e595225.cdn.sohucs.com/images/20190313/b7186996f52148b8970f97ae33dfa45b.jpeg4.仪表符号http://5b0988e595225.cdn.sohucs.com/images/20190313/67621f85c86a4508b12c798b22970783.jpeg5.传感器符号http://5b0988e595225.cdn.sohucs.com/images/20190313/af0956a205544a6bb4cd7f5ea3fe255c.jpeg6.汽车12V电路主要导线情况http://5b0988e595225.cdn.sohucs.com/images/20190313/ed0f791336b64003a1b926c98c64bd15.jpeg二、电源系统1.蓄电池http://5b0988e595225.cdn.sohucs.com/images/20190313/a3267f3fdfbf4c3da6ac7b411df7240b.jpeg2.蓄电池的充放电过程http://5b0988e595225.cdn.sohucs.com/images/20190313/0214dfdf92c240219c8799921ec5c75e.jpeg3.充电系统—交流发电机发电原理http://5b0988e595225.cdn.sohucs.com/images/20190313/ecef87ec4f264eaab78e2d23c75db726.jpeg4.交流发电机整流原理http://5b0988e595225.cdn.sohucs.com/images/20190313/0a175798c00148ad82a8afc9b95e17fd.jpeg5.发电机发电电压较低时电路原理http://5b0988e595225.cdn.sohucs.com/images/20190313/b5195c1fbc4d4dbf99f18dba4dd0bc78.jpeg6.9管交流发电机、11管交流发电机http://5b0988e595225.cdn.sohucs.com/images/20190313/29ce63568f884d838bb2acbf150453b4.jpeg7.集成电路式电压调节器及充电系统电路http://5b0988e595225.cdn.sohucs.com/images/20190313/cc94269668a14c68b0766bc76e0a4705.jpeg三、起动系统1.起动机的组成http://5b0988e595225.cdn.sohucs.com/images/20190313/334b71d3c1c84c6096489f6906bfaf2b.jpeg2.电磁开关的工作原理http://5b0988e595225.cdn.sohucs.com/images/20190313/bcb82d37b0874553975a1f85d13e8766.jpeg3.带继电器的起动控制电路http://5b0988e595225.cdn.sohucs.com/images/20190313/7a34045d345f408f882d29615c4843df.jpeg四、点火系统http://5b0988e595225.cdn.sohucs.com/images/20190313/77e3b73a4fed43798a854accf6999a69.jpega)传统点火系统 b)电子点火系统 c)微机控制点火系统点火系统示意图http://5b0988e595225.cdn.sohucs.com/images/20190313/599421aa579344b2a84c2301abf9f3f2.jpeg传统点火系统基本工作原理(触点闭合时)http://5b0988e595225.cdn.sohucs.com/images/20190313/a9ea572b690a489d96302172cea3c7a1.jpeg传统点火系统基本工作原理(触点断开时)http://5b0988e595225.cdn.sohucs.com/images/20190313/8c9a3f8f7ead40288d50644d3c419847.jpeg五、照明与信号系统1.转向灯、危险警告灯控制电路http://5b0988e595225.cdn.sohucs.com/images/20190313/5c459d1b019948ed9e139bdbcdf4c85a.jpeg2.仪表和报警系统—汽车组合仪表板http://5b0988e595225.cdn.sohucs.com/images/20190313/78782761467f40e2ada9e2f6e585917a.jpeg3.冷却液温度表工作原理http://5b0988e595225.cdn.sohucs.com/images/20190313/7c992f1f2a474d02b273e3096bca9ccd.jpeg4.燃油表的工作原理http://5b0988e595225.cdn.sohucs.com/images/20190313/9ba7ba9f6366450c9ba759087c4833cf.jpeg5.车速里程表的工作原理http://5b0988e595225.cdn.sohucs.com/images/20190313/1de8daa8d53341b08ca8496243e5452d.jpeg6.发动机转速表的工作原理http://5b0988e595225.cdn.sohucs.com/images/20190313/2854c245487247bf880196b54f198749.jpeg7.汽车警告灯http://5b0988e595225.cdn.sohucs.com/images/20190313/4c12c7d233544b9cb11748338c5af8a2.jpeghttp://5b0988e595225.cdn.sohucs.com/images/20190313/bf6f5241bc364162bdf1f117bcf0ba74.jpeghttp://5b0988e595225.cdn.sohucs.com/images/20190313/3eefa07cab33428a822fd3025223c82c.jpeg六、辅助电气系统1.丰田卡罗拉刮水器与洗涤器电路图http://5b0988e595225.cdn.sohucs.com/images/20190313/cebdfe83d5b64b1eb081df1f94351cf9.jpeg2.丰田车型刮水器电路图http://5b0988e595225.cdn.sohucs.com/images/20190313/49650ad869534d87b55922643beaf17b.jpeg3.通用凯越刮水器电路图http://5b0988e595225.cdn.sohucs.com/images/20190313/fe5e0391f55e4bb0816028fefbfd977e.jpeg4.电动车窗电路图http://5b0988e595225.cdn.sohucs.com/images/20190313/b0603fe688f9403a936ee33830d61ce6.jpeg5.电动车窗主控开关位置图http://5b0988e595225.cdn.sohucs.com/images/20190313/68c04f8afb714d14a7630817fee91e77.jpeg6.电动门锁电路http://5b0988e595225.cdn.sohucs.com/images/20190313/d6b578d8e01249df9fe596360f78ef57.jpeg7.电动后视镜电路http://5b0988e595225.cdn.sohucs.com/images/20190313/582e0ace299a4213b53bd1f01c3e9041.jpeg汽车线路故障诊断与检修的常用方法(1)直观法 当汽车电系的某个部分发生故障时,会出现冒烟、火花、异响、焦臭、高温等异常现象。通过人体的感觉器官,听、摸、闻、看等对汽车电器进行直观检查,进而判断出故障的所在部位,从而大大地提高了检修速度。检查保险法 当汽车电系出现故障时,首先应查看保险是否完好。如汽车在行驶中,若某个电器突然停止工作,同时该支路上的熔断器熔断,说明该支路有搭铁故障存在。某个系统的保险反复烧断,则表明该系统一定有类似搭铁的故障存在,不应只更换熔断器了事。(2)刮火法 刮火法又称试火法,通常应用于判断线束或导线有无开路。拆下用电设备的某一线头对汽车的金属部分(打铁)碰试,根据火花的有无,判断是否开路。注意:刮火不宜用来检查汽车电子电路,以免损坏电子元件器材。(3)试灯法 用一个汽车灯泡作为临时试灯,检查线束是否开路或短路,电器或电路有无故障等。此方法特别适合于检查不允许直接短路的带有电子元器件的电器。使用临时试灯法应注意试灯的功率不要太大,在测试电子控制器的控制(输出)端子是否有输出及是否有足够的输出时尤其要慎重,防止使控制器超载损坏。(4)短路法 短路法又叫短接法,即用一根导线将某段导线或某一电器短接后观察用电器的变化。(5)替换法 替换法常用于故障原因比较复杂的情况,能对可能产生的原因逐一进行排除。其具体做法是:用一个已知是完好的零部件来替换被认为或怀疑是有故障的零部件,这样做可以试探出怀疑是否正确。若替换后故障消除,说明怀疑成立;否则,装回原件,进行新的替换,直至找到真正的故障部位。维修汽车电气系统的首要原则是不要随意更换电线或电器,这种操作有可能因短路、过载而引起火灾。同时还应注意以下各项:1.拆卸蓄电池时,总是最先拆下负极(-)电缆;装上蓄电池时,总是最后连接负极(-)电缆。拆下或装上蓄电池电缆时,应确保点火开关或其他开关都已断开,否则会导致半导体元器件的损坏。切勿颠倒蓄电池接线柱极性。2.允许使用欧姆表及万用表的R×100以下低阻欧姆挡检测小功率晶体三极管,以免电流过载损坏它们。更换三极管时,应首先接入基极,拆卸时,则应最后拆卸基极。对于金属氧化物半导体管(MOS),则应当心静电击穿,焊接时,应丛电源上拔下烙铁插头。3.拆卸和安装元件时,应切断电源。如无特殊说明,元件引脚距焊点应在10mm以上,以免烙铁烫坏元件,且宜使用恒温或功率小于75W的电烙铁。4.更换烧坏的保险时,应使用相同规格的保险。使用比规定容量大的保险会导致电气损坏或产生火灾。5.靠近震动部件(如发动机)的线束部分应用卡子固定,将松弛部分拉紧,以免由于震动造成线束与其他部件接触。6.不要粗暴地对待电器,也不能随意乱仍。无论好坏器件,都应轻拿轻放。以免使其承受过大冲击。7.与尖锐边缘磨碰的线束部分应用胶带缠起来,以免损坏。安装固定零件时,应确保线束不要被夹住或被破坏,同时应确保接插头接插牢固。8.进行保养时,若温度超过80℃(如进行焊接时),应先拆下对温度敏感的零件(如ECU)。
vov_m2Fjn 发表于 2019-3-13 19:57:44
cjs1971 发表于 2019-3-13 20:03:06
陈波 发表于 2019-3-13 20:10:40
生命有明天 发表于 2019-3-13 20:11:21
感恩无私的分享与奉献 :)
在人间 发表于 2019-3-13 20:15:47
如浪 发表于 2019-3-13 20:58:46
赖宜谷 发表于 2019-3-14 23:16:17
感谢{author}无私分享!
@Xizi_yE0Mjfrw 发表于 2019-4-10 18:32:10
huawei123 发表于 2019-5-5 13:05:10
页: [1] 2 3
查看完整版本: 汽车电控系统很神秘?一文解开他的神秘面纱!
