查看: 1986|回复: 12
C# 16进制字符串转换byte[]数组
发表于 2021-8-18 21:07:37 | 显示全部楼层 |阅读模式
static void Main(string[] args)
    // 16进制字符串, 0x000000000002654D
    string str = "000000000002654D";// 或者 02654D
    // 16进制字符串 -> bytes
    byte[] a = BytesToHexString(str);
    // bytes -> 16进制字符串
    string hex = BytesToHexString(a);
    // 转换数值
    long b = Convert.ToInt64(hex, 16);
    Console.Read();
/// <summary>
/// 16进制字符串转byte数组
/// </summary>
/// <param name="hexString">16进制字符</param>
/// <returns></returns>
public static byte[] BytesToHexString(string hexString)
    // 将16进制秘钥转成字节数组
    byte[] bytes = new byte[hexString.Length / 2];
    for (var x = 0; x < bytes.Length; x++)
        var i = Convert.ToInt32(hexString.Substring(x * 2, 2), 16);
        bytes[x] = (byte)i;
    return bytes;
/// <summary>
/// byte数组转16进制字符串
/// </summary>
/// <param name="bytes">byte数组</param>
public static string BytesToHexString(byte[] bytes)
    StringBuilder sb = new StringBuilder(bytes.Length * 3);
    foreach (byte b in bytes)
        sb.Append(Convert.ToString(b, 16).PadLeft(2, '0'));
    return sb.ToString().ToUpper();
发表于 2021-8-18 21:07:38 | 显示全部楼层
发表于 2021-8-20 00:12:06 | 显示全部楼层
发表于 2025-11-12 11:55:18 | 显示全部楼层
发表于 2025-11-12 12:16:41 | 显示全部楼层
发表于 2025-11-12 12:34:28 | 显示全部楼层
发表于 2025-11-12 12:37:33 | 显示全部楼层
发表于 2025-11-12 12:43:22 | 显示全部楼层
发表于 2025-11-12 13:34:01 | 显示全部楼层
发表于 2025-11-14 13:05:31 | 显示全部楼层
GMT+8, 2025-12-23 04:59 , Processed in 0.079237 second(s), 26 queries .
