工控课堂 首页 工控文库 上位机编程 查看内容
C# 操作Linq, 查找, 获取, 合并, 排序
2021-11-8 21:09| 发布者: gk-auto| 查看: 1252| 评论: 0
摘要: C# 操作Linq, 查找, 获取, 合并, 排序using System;using System.Collections.Generic;using System.Linq;namespace CSharpLinq{class Program{static void Main(string args){ListEmplayee emplayeeList = GetEmpla ...
using System;
using System.Linq;
    class Program
        static void Main(string[] args)
            List<Emplayee> emplayeeList = GetEmplayeeList();  // 初始化人员列表
            // 获取人员Id数组
            // xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
            Guid[] arr = emplayeeList.Select(a => a.Id).ToArray();
            // 获取指定人员信息
            var emplayee = (from a in emplayeeList where a.Id == new Guid("{875d217d-840f-470d-be03-8fb3a814d9c6}") select a).FirstOrDefault();
            // 获取性别女的人员
            var emplayee2 = (from a in emplayeeList where a.Sex == "女"<
GMT+8, 2025-12-23 02:26 , Processed in 0.083065 second(s), 23 queries .
