好记性不如烂博客;stl源码剖析那本书不想看,没事(有事懒得做)看看微软的vector实现。 以vector<int> 为例 template <class _Ty, class _Alloc = allocator<_Ty>> class vector { // varying size array of values private: template <class> friend class _Vb_val;//???? friend _Tidy_guard<vector>; using _Alty = _Rebind_alloc_t<_Alloc, _Ty>;//会区分是不是默认分配器_Default_allocator_traits或自定义allocator,是默认的话,就是本身allocator<int>,否则。。。模板嵌套太多了。。 using _Alty_traits = allocator_traits<_Alty>; public: static_assert(!_ENFORCE_MATCHING_ALLOCATORS || is_same_v<_Ty, typename _Alloc::value_type>, _MISMATCHED_ALLOCATOR_MESSAGE("vector<T, Allocator>", "T")); using value_type = _Ty;//int using allocator_type = _Alloc;// using pointer = typename _Alty_traits::pointer; using const_pointer = typename _Alty_traits::const_pointer; using reference = _Ty&; using const_reference = const _Ty&; using size_type = typename _Alty_traits::size_type; using difference_type = typename _Alty_traits::difference_type; private: //_INLINE_VAR constexpr bool _Is_simple_alloc_v = is_same_v<typename allocator_traits<_Alloc>::size_type, size_t>&& using _Scary_val = _Vector_val<conditional_t<_Is_simple_alloc_v<_Alty>, _Simple_types<_Ty>, _Vec_iter_types<_Ty, size_type, difference_type, pointer, const_pointer, _Ty&, const _Ty&>>>;//是否是simple类型,选择不同的types, _CONSTEXPR20_CONTAINER explicit vector(const _Alloc& _Al) noexcept : _Mypair(_One_then_variadic_args_t{}, _Al) { _Mypair._Myval2._Alloc_proxy(_GET_PROXY_ALLOCATOR(_Alty, _Getal())); }可以看到这些都涉及到了大量的模板元编程。先看下_Compressed_pair是什么,有两个模板参数_Alty, _Scary_val,第一个已经知道是什么了allocator<int>, 第二个呢?是一个_Vector_val类型。基本看出这个类型才是真正的数据载体以及维护者 class _Vector_val : public _Container_base {// 基类里有个_Container_proxy* _Myproxy,维护迭代器的一个东西。 public: using value_type = typename _Val_types::value_type; using size_type = typename _Val_types::size_type; using difference_type = typename _Val_types::difference_type; using pointer = typename _Val_types::pointer; using const_pointer = typename _Val_types::const_pointer; using reference = value_type&; using const_reference = const value_type&; _CONSTEXPR20_CONTAINER _Vector_val() noexcept : _Myfirst(), _Mylast(), _Myend() {} _CONSTEXPR20_CONTAINER _Vector_val(pointer _First, pointer _Last, pointer _End) noexcept : _Myfirst(_First), _Mylast(_Last), _Myend(_End) {} _CONSTEXPR20_CONTAINER void _Swap_val(_Vector_val& _Right) noexcept { this->_Swap_proxy_and_iterators(_Right); _Swap_adl(_Myfirst, _Right._Myfirst); _Swap_adl(_Mylast, _Right._Mylast); _Swap_adl(_Myend, _Right._Myend); } _CONSTEXPR20_CONTAINER void _Take_contents(_Vector_val& _Right) noexcept { this->_Swap_proxy_and_iterators(_Right); _Myfirst = _Right._Myfirst; _Mylast = _Right._Mylast; _Myend = _Right._Myend; _Right._Myfirst = nullptr; _Right._Mylast = nullptr; _Right._Myend = nullptr; } pointer _Myfirst; // pointer to beginning of array 指针维护数据结构 pointer _Mylast; // pointer to current end of sequence pointer _Myend; // pointer to end of array }; 再接着看_Compressed_pair,目前标准容器库的实现大致都是这样的模式。实际是继承第一个模板参数,那么本身就是一个分配器。并持有一个_Vector_val 的变量。基本所有的东西都齐全了,第一个参数分配数据,第二个模板参数管理数据。 template <class _Ty1, class _Ty2, bool = is_empty_v<_Ty1> && !is_final_v<_Ty1>> class _Compressed_pair final : private _Ty1 { // store a pair of values, deriving from empty first public: _Ty2 _Myval2; using _Mybase = _Ty1; // for visualization template <class... _Other2> constexpr explicit _Compressed_pair(_Zero_then_variadic_args_t, _Other2&&... _Val2) noexcept(//标签派发 conjunction_v<is_nothrow_default_constructible<_Ty1>, is_nothrow_constructible<_Ty2, _Other2...>>) : _Ty1(), _Myval2(_STD forward<_Other2>(_Val2)...) {} template <class _Other1, class... _Other2> constexpr _Compressed_pair(_One_then_variadic_args_t, _Other1&& _Val1, _Other2&&... _Val2) noexcept( conjunction_v<is_nothrow_constructible<_Ty1, _Other1>, is_nothrow_constructible<_Ty2, _Other2...>>) : _Ty1(_STD forward<_Other1>(_Val1)), _Myval2(_STD forward<_Other2>(_Val2)...) {} constexpr _Ty1& _Get_first() noexcept { return *this;//返回分配器,就是自身 } constexpr const _Ty1& _Get_first() const noexcept { return *this; } }; 现在来看具体的构造过程,在构造函数里都有Alloc_proxy函数,看它的实现 template <class _Alloc> _CONSTEXPR20_CONTAINER void _Alloc_proxy(_Alloc&& _Al) {//注意此时的_Al 是 allocator<container_proxy>,因为重新生成了一个allocator,具体看上面的_GET_PROXY_ALLOCATOR _Myproxy = _New_proxy; 这个应该是维护迭代器的,目前只是初始化完成。接着看下vector的push_back操作,因为push_back内部操作还是调用了emplace_back。区分了左值和右值的参数调用。 template <class... _Valty> _CONSTEXPR20_CONTAINER decltype(auto) emplace_back(_Valty&&... _Val) { // insert by perfectly forwarding into element at end, provide strong guarantee auto& _My_data = _Mypair._Myval2; pointer& _Mylast = _My_data._Mylast; if (_Mylast != _My_data._Myend) {//last!=end 可以理解为capacity大于size,利用已有的多余内存构建数据。 return _Emplace_back_with_unused_capacity(_STD forward<_Valty>(_Val)...); } _Ty& _Result = *_Emplace_reallocate(_Mylast, _STD forward<_Valty>(_Val)...);//新分配内存 #if _HAS_CXX17 return _Result; #else // ^^^ _HAS_CXX17 ^^^ // vvv !_HAS_CXX17 vvv (void) _Result; #endif // _HAS_CXX17 } vector的内存分配方式,大多网上都有讲,这里具体看下采用什么样的内存分配策略。 template <class... _Valty> _CONSTEXPR20_CONTAINER pointer _Emplace_reallocate(const pointer _Whereptr, _Valty&&... _Val) { // reallocate and insert by perfectly forwarding _Val at _Whereptr _Alty& _Al = _Getal(); auto& _My_data = _Mypair._Myval2; pointer& _Myfirst = _My_data._Myfirst; pointer& _Mylast = _My_data._Mylast; _STL_INTERNAL_CHECK(_Mylast == _My_data._Myend); // check that we have no unused capacity const auto _Whereoff = static_cast<size_type>(_Whereptr - _Myfirst);//whereptr代表放入数据的位置 const auto _Oldsize = static_cast<size_type>(_Mylast - _Myfirst);//当前的size大小 if (_Oldsize == max_size()) { _Xlength();//数据太大 } const size_type _Newsize = _Oldsize + 1;//已有的数据上新加一个 const size_type _Newcapacity = _Calculate_growth(_Newsize); ////////////////////////////////////////////////////////////////// _CONSTEXPR20_CONTAINER size_type _Calculate_growth(const size_type _Newsize) const { if (_Oldcapacity > _Max - _Oldcapacity / 2) { const size_type _Geometric = _Oldcapacity + _Oldcapacity / 2;//在旧的大小基础上加一半,1 , 2, 3 ,4,5, 7增长方式,前几个每次都会重新分配内存, if (_Geometric < _Newsize) { return _Geometric; // geometric growth is sufficient 返回的大小一定大于等于newsize } ////////////////////////////////////////////////////////////////////////const pointer _Constructed_last = _Newvec + _Whereoff + 1;
pointer _Constructed_first = _Constructed_last;
_TRY_BEGIN
_Alty_traits::construct(_Al, _Unfancy(_Newvec + _Whereoff), _STD forward<_Valty>(_Val)...);//在新分配的内存里,构建新加入的数据
_Constructed_first = _Newvec + _Whereoff;
if (_Whereptr == _Mylast) { // at back, provide strong guarantee
_Umove_if_noexcept(_Myfirst, _Mylast, _Newvec);//将旧数据移动到新的内存里。
} else { // provide basic guarantee
_Umove(_Myfirst, _Whereptr, _Newvec);
_Constructed_first = _Newvec;
_Umove(_Whereptr, _Mylast, _Newvec + _Whereoff + 1);
_CATCH_ALL
_Destroy(_Constructed_first, _Constructed_last);//异常捕捉
_Al.deallocate(_Newvec, _Newcapacity);
_RERAISE;
_CATCH_END
_Change_array(_Newvec, _Newsize, _Newcapacity);//因为容器重分配内存,需要重新调整,first,last,end指针,同时让所有的迭代器失效
return _Newvec + _Whereoff;
}上面是重新分配数据的逻辑,如果capacity较大时,则会在已有的内存上构建数据。 template <class... _Valty> _CONSTEXPR20_CONTAINER decltype(auto) _Emplace_back_with_unused_capacity(_Valty&&... _Val) { // insert by perfectly forwarding into element at end, provide strong guarantee auto& _My_data = _Mypair._Myval2; pointer& _Mylast = _My_data._Mylast; _STL_INTERNAL_CHECK(_Mylast != _My_data._Myend); // check that we have unused capacity _Alty_traits::construct(_Getal(), _Unfancy(_Mylast), _STD forward<_Valty>(_Val)...); _Orphan_range(_Mylast, _Mylast);//使迭代器失效 _Ty& _Result = *_Mylast; ++_Mylast; #if _HAS_CXX17 return _Result; #else // ^^^ _HAS_CXX17 ^^^ // vvv !_HAS_CXX17 vvv (void) _Result; #endif // _HAS_CXX17 } 关于迭代器的问题,是由container_proxy管理的,当创建一个迭代器的时候,调用如下函数,proxy记录相关信息 _CONSTEXPR20_CONTAINER void _Adopt_unlocked(const _Container_base12* _Parent) noexcept { if (!_Parent) { _Orphan_me_unlocked_v3(); return; } _Container_proxy* _Parent_proxy = _Parent->_Myproxy; if (_Myproxy != _Parent_proxy) { // change parentage if (_Myproxy) { // adopted, remove self from list _Orphan_me_unlocked_v3(); } _Mynextiter = _Parent_proxy->_Myfirstiter;//每次adopt,proxy记录的迭代器都会更新为当前,把上一个记录在_Mynextiter里,形成一个chain _Parent_proxy->_Myfirstiter = this; _Myproxy = _Parent_proxy;//当一个迭代器的_Myproxy为空时,即为失效,比如push_back后,end()迭代器就会失效 } } 具体可以看源码,看看在那些地方调用了orphan_range操作。关键部分大概就是这样了,详细的细节看下源码应该问题不大。
template <class _Alloc> struct _Default_allocator_traits { // traits for std::allocator using allocator_type = _Alloc; using value_type = typename _Alloc::value_type; using pointer = value_type*; using const_pointer = const value_type*; using void_pointer = void*; using const_void_pointer = const void*; using size_type = size_t;//默认的size_t using difference_type = ptrdiff_t; using propagate_on_container_copy_assignment = false_type; using propagate_on_container_move_assignment = true_type; using propagate_on_container_swap = false_type; using is_always_equal = true_type; template <class _Other> using rebind_alloc = allocator<_Other>; template <class _Other> using rebind_traits = allocator_traits<allocator<_Other>>; .... }
GMT+8, 2025-12-23 04:45 , Processed in 0.118710 second(s), 23 queries .
