来源:Stackoverflow NET技术问答 https://mp.weixin.qq.com/s/0HLPS9XQQnNS61mbMTNOuw 咨询区我有下面的查询语句: set ANSI_NULLS ON set QUOTED_IDENTIFIER ON go
ALTER PROCEDURE [dbo].[Validate] @a varchar(50), @b varchar(50) output
AS
SET @Password = (SELECT Password FROM dbo.tblUser WHERE Login = @a)
RETURN @b GO
编译都是没有问题的,现在我想执行这条sql并获取最后的返回值,我的代码是这样的。 SqlConnection SqlConn = new SqlConnection(System.Configuration.ConfigurationManager.ConnectionStrings["MyLocalSQLServer"].ConnectionString.ToString()); System.Data.SqlClient.SqlCommand sqlcomm = new System.Data.SqlClient.SqlCommand("Validate", SqlConn);
string returnValue = string.Empty;
try { SqlConn.Open(); sqlcomm.CommandType = CommandType.StoredProcedure;
SqlParameter param = new SqlParameter("@a", SqlDbType.VarChar); param.Direction = ParameterDirection.Input; param.Value = Username; sqlcomm.Parameters.Add(param);
SqlParameter retval = sqlcomm.Parameters.Add("@b", SqlDbType.VarChar); retval.Direction = ParameterDirection.ReturnValue;
string retunvalue = (string)sqlcomm.Parameters["@b"].Value;
为了简洁,我去掉了所有的异常判断,不知道为啥 retunvalue 一直都返回 null ,请问这段代码是否有逻辑错误? 回答区如果你不通过 select 语句 还要获取 存储过程 的返回值,你就必须要指定 ParameterDirection.ReturnValue 枚举并通过 ExecuteScalar 获取返回值,参考我的案例。 CREATE PROCEDURE IsEmailExists @Email NVARCHAR(20) AS BEGIN -- SET NOCOUNT ON added to prevent extra result sets from -- interfering with SELECT statements. SET NOCOUNT ON;
-- Insert statements for procedure here IF EXISTS(SELECT Email FROM Users where Email = @Email) BEGIN RETURN 0 END ELSE BEGIN RETURN 1 END END
然后是 C# 代码。 GetOutputParaByCommand("IsEmailExists")
public int GetOutputParaByCommand(string Command) { object identity = 0; try { mobj_SqlCommand.CommandText = Command; SqlParameter SQP = new SqlParameter("returnVal", SqlDbType.Int); SQP.Direction = ParameterDirection.ReturnValue; mobj_SqlCommand.Parameters.Add(SQP); mobj_SqlCommand.Connection = mobj_SqlConnection; mobj_SqlCommand.ExecuteScalar(); identity = Convert.ToInt32(SQP.Value); CloseConnection(); } catch (Exception ex) {
CloseConnection(); } return Convert.ToInt32(identity); }
这样就可以成功获取 存储过程 的返回值了。 如果你的项目采用的是 Dapper 的话,可以参考我的实现。
select ID, FILE_NAME from dbo.FileStorage where ID = (select max(ID) from dbo.FileStorage);
var data = (_dbConnection.Query<FileUploadQueryResponse> ("dbo.insertFile", whateverParameters, commandType: CommandType.StoredProcedure)).ToList(); var storedFileName = data[0].FILE_NAME; var id = data[0].ID;
为了能获取返回值,这里我定义了一个复杂类型 FileUploadQueryResponse 来接受存储过程的 return value。 public class FileUploadQueryResponse { public string ID { get; set; } public string FILE_NAME { get; set; } }
点评区虽然现代开发中很少用存储过程了,但现实项目中还是有很多遗留的 存储过程 存在,所以如何获取返回值还是有必要了解一下。
