时间限制: 1S类别: DS:线性表->线性表应用 题目描述:
输入范例: -534564675768465476586798709880985345646757684654765867987098809853456467576846547658679870988098534564675768465476586798709880985345646757684654765867987098809853456467576846547658679870988098534564675768465476586798709880985345646757684654765867987098809853456467576846547658679870988098534564675768465476586798709880985345646757684654765867987098809853456467576846547658679870988098
-5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098 -5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,6467,5768,4654,7658,6798,7098,8098,5345,2111,1392,9797,7801,8855,1455,0549,9647,0788,1412,0279,2801,6941,9155,2454,7797,0769,0089,0298,3283,1941,7242,0154,9701,8919,0069,8975,3302,2423,2241,8241,7402,0823,8219,8956,1979,2442,2723,3241,5488,8524,0124,7106,1960,1119,2742,3723,0488,6610,7824,9011,0110,1100,1419,3742,0970,1610,5911,6711,2014,9250,1400,2419
这里利用了几个关键函数:链表的逆置 比较两个链表的绝对值大小 链表的相加 输出链表
我的题解: //DHUOJ 单链表ADT模板应用算法设计:长整数加法运算(使用单链表存储计算结果) #include<iostream> #include<cstring>using namespace std; template<class ElemType> struct Node { ElemType data; Node<ElemType>* next; //构造函数1 用于node构造头结点 Node(Node<ElemType>* ptr = NULL) { next = ptr; } //构造函数2 用于构造其他结点 Node(const ElemType& item, Node<ElemType>* ptr = NULL) { next = ptr; data = item; } public: ElemType getdata() { return data; } Node<ElemType>* getnext() { return next; } void set_next(Node<ElemType>* p) { this->next = p; } void set_date(ElemType num) { this->data = num; } }; template<class ElemType> class LinkList { private: Node<ElemType>* head;//头指针 Node<ElemType>* tail;//尾指针 public: //无参构造函数 LinkList() { head = new Node<ElemType>; head->next = NULL; tail = head->next;//头尾指针指向同一个内存 } //有参构造 LinkList(const ElemType& item) { head = new Node<ElemType>; tail = new Node<ElemType>; head->next = tail = new Node<ElemType>(item);//有参构造node } void display() { //避免出现以下情况 所以我们先判断是不是就一个单0 if(head->getnext()->getdata()==0&&head->getnext()->getnext()==NULL) { cout<<"0"; return ; } if (head->getdata() == -1) cout << "-";//如果是0就不能输出负号 //其实这样写也有问题 如果-0000 0005的就无法判断 所以我们上面解决了单0的情况 Node<ElemType>* q = head->next; bool zeroflag = 0; bool firstflag = 0; //0要先特判 避免出现0 0000 0000的情况 也不行 会出现0 0000 0005 的情况无法输出 while (q->next) { if (q->getdata() == 0 && !zeroflag) { q = q->next; continue; } else if(q->getdata()!=0&&!zeroflag) { zeroflag = 1; } if (!firstflag) { cout << abs(q->data) << ","; firstflag = 1; } else printf("%04d,", abs(q->data)); q = q->next; } if (q == head->next)//只有一位特判 cout << abs(q->data); else { if (!firstflag) { cout << abs(q->data); } else { if (!zeroflag) { cout << abs(q->data); } else { printf("%04d", abs(q->data)); } } } cout << endl; } int size() { if (head->next == NULL) return 0; int len = 0; Node<ElemType>* q; q = head->next; while (q) { len++; q = q->next; } return len; } void push_back(ElemType x) { Node<ElemType>* q = new Node<ElemType>;//新建结点 q->data = x; q->next = NULL; if (size() == 0) { head->next = q; } else { tail->next = q; } tail = q; } Node<ElemType>* get_front(Node<ElemType>* p) {//获取一个指针的上一个,头指针和非法指针会报错. Node<ElemType>* q; q = head->next; while (q->next != NULL) { if (q->next == p) return q; q = q->next; } } Node<ElemType>* get_next(Node<ElemType>* p) { return p->next; } Node<ElemType>* get_address(int i)//获取指定下标的地址 { Node<ElemType>* q; q = head->next; while (i--) q = q->next; return q; } ElemType at(int i) { Node<ElemType>* q = get_address(i); return q->data; } bool del_p(Node<ElemType>* p)//传入一个指针 删除 { if (size() == 0) return false; if (tail->next == NULL)//如果只有一个元素 { if (p == tail)//如果这个指针是那个唯一的指针 { delete tail; tail = NULL; return true; } else return false;//如果不是 } if (p == tail)//如果删除的是尾指针 { Node<ElemType>* q = get_front(p); q->next = NULL; tail = q; delete p; return true; } //其他的 Node<ElemType>* q = get_front(p); q->next = p->next; delete p; return true; } bool del(int i)//删除指定位置的元素 { return del_p(get_address(i)); } Node<ElemType>* get_head() { return head; } Node<ElemType>* get_tail() { return tail; } void set_head(Node<ElemType>* p) { head = p; } void set_tail(Node<ElemType>* p) { tail = p; } void ListReverse() { Node<ElemType>* a, * b, * temp; a = head->getnext(); ElemType datas = head->getdata(); temp = NULL; b = NULL; bool flag = 0;//设置尾指针的标志 while (a) { b = a; a = a->getnext(); b->set_next(temp); if (!flag) { tail = b; flag = 1; } temp = b; } Node<ElemType>* newhead = new Node<ElemType>; newhead->set_next(b); newhead->set_date(datas); head = newhead; } }; //从长整数的低位开始拆分(4位为一组,即不超过9999的非负整数),依次存放在单链表的每个结点的数据域中; //头结点的数据域存放正负数标志(正数或0:1,负数:-1)。 template<class ElemType> void Input_Int_Division(LinkList<ElemType>& L, string& str, int& length) { Node<ElemType>* head = L.get_head(); bool zhengfu_flag = 0;//记录正负的flag int l = str.length(); if (str[0] == '-')//先特判正负数 { zhengfu_flag = 1; head->set_date(-1); } else { head->set_date(1); } int i = 0; if (zhengfu_flag) i = 1; int t0 = l % 4; if (t0 == 0) t0 = 4; int t = 0;//记录位数 int num = 0;//存四位数 bool changeflag = 0;//判断标志 判断是否有进行第一次 for (; i < t0; ++i) { num = num * 10 + (str[i] - '0'); changeflag = 1; } if (changeflag) { length++;//记录长度 L.push_back(num); num = 0; } for (; i < str.length(); ++i) { num = num * 10 + (str[i] - '0'); t++; if (t == 4) { length++;//记录长度 L.push_back(num); t = 0; num = 0; } } //L.display(); } //两个长整数的 绝对值 大小比较 //(x>y 返回值为1;x<y 返回值为2;x=y 返回值为0;) template<class ElemType> int Two_LongNum_Compare(LinkList<ElemType>& A, LinkList<ElemType>& B, const int& len_A, const int& len_B) { Node<ElemType>* head1 = A.get_head(); Node<ElemType>* head2 = B.get_head(); //正数的情况 先看长度 if (len_A > len_B) { return 1; } else if (len_A < len_B) { return 2; } else if (len_A == len_B) { Node<ElemType>* a, * b; a = head1->getnext(); b = head2->getnext(); while (a) { if (a->getdata() > b->getdata()) return 1; else if (a->getdata() < b->getdata()) return 2; else a = a->getnext(), b = b->getnext(); } return 0; } } template<class ElemType> void swaps(LinkList<ElemType>& a, LinkList<ElemType>& b) { LinkList<ElemType>temp = a; a = b; b = temp; } template<class ElemType> void Listadds(LinkList<ElemType>& a, LinkList<ElemType>& b, int& la, int& lb) { Node<ElemType>* x, * y; int ans = 0; if (la < lb) { //swap一下两个 swaps(a, b); int temp = la; la = lb; lb = temp; } x = a.get_head()->getnext(); y = b.get_head()->getnext();//两个指针的创建必须放在 交换判断之后 int m = a.get_head()->getdata();//m n 存储符号 int n = b.get_head()->getdata();//存储符号也必须放在交换判断之后 //第一步 判断结果的最高位//!必须再加法前进行 !!因为a会随着加法而改变 引用传递 bool flag = 0;//标记元素 int comp = Two_LongNum_Compare(a, b, la, lb); while (y)//先把每一位结点的数值加起来 { ans = x->getdata() * m + y->getdata() * n; x->set_date(ans); x = x->getnext(); y = y->getnext(); } //把长的位都化成同号的 不然接下来进位会出问题 while (x) { x->set_date(x->getdata() * m); x = x->getnext(); } //再做进位处理 if (comp == 1) { flag = 1; } //第二步 开始逐位遍历 x = a.get_head()->getnext(); int zheng_fu = 0;//判断正负的符号 if (flag) zheng_fu = a.get_head()->getdata(); else zheng_fu = b.get_head()->getdata(); if (zheng_fu > 0)//分正负两种情况 先看是正的 { a.get_head()->set_date(1);//定最高位符号 while (x->getnext())//最后一个结点先不遍历 最后单独讨论 { if (x->getdata() > 9999) { x->set_date(x->getdata() - 10000); x->getnext()->set_date(x->getnext()->getdata() + 1); //下一位就加一 } else if (x->getdata() < 0) { x->set_date(x->getdata() + 10000); x->getnext()->set_date(x->getnext()->getdata() - 1); } x = x->getnext(); } //讨论最后一位 是否要进位 if (x->getdata() > 9999) { x->set_date(x->getdata() - 10000); a.push_back(1); } } else //讨论负数的情况 { a.get_head()->set_date(-1);//定最高位符号 while (x->getnext())//最后一个结点先不遍历 最后单独讨论 { if (x->getdata() < -9999) { x->set_date(x->getdata() + 10000); x->getnext()->set_date(x->getnext()->getdata() - 1); //下一位就加一 } else if (x->getdata() > 0) { x->set_date(x->getdata() - |
GMT+8, 2025-12-22 19:58 , Processed in 0.129725 second(s), 23 queries .
